Lift Help, what do I HAVE to have? - Ford Powerstroke Diesel Forum
Old 07-15-2010, 12:57 PM
I have a 2000 F250 4x4 and it currently just has 2" add a leafs all the way around. Well I have a 4.5" shackle/hanger kit for the front and the shackle flip for the rear. Currently all I have are the shackle/hangers for the front and the flip for the rear. What else do I HAVE to have to install the lift? Id like to put it on but an currently short on cash so I cant just put everything on. I could also possibly make some of the parts as I have a welder and access to some tools.
I understand I need new shocks but I need to replace mine anyways. So other than that what do I have to have to install it?
Thanks
Old 07-15-2010, 01:16 PM
Trac bar, drop links for the sway bar...then an alignment and you should be good to go
Might be more you need, so don't hold me to it till others chime in
Old 07-16-2010, 10:41 AM
Feedback Score: 5 reviews
Did you get a kit or just the hangers?
Cary
Old 07-16-2010, 11:45 AM
Just the hangers. Its just the front hangers and shackles and the rear flip
Old 07-16-2010, 12:21 PM
You need as stated above:
Drop Pitman arm
drop track bar bracket
longer swaybar links
longer shocks..IMO Bilsteins
At this time you may want to get longer SS brake lines..not required
Also new U bolts unless you don't remove them for the install.
A carrier bearing shim kit
Do you relize shackle flips will shift the rear axle forward?
Cary
