trans fluid change - Ford Powerstroke Diesel Forum
Old 05-22-2007, 01:29 PM
trans fluid change
getting ready to change out the transmission fluid.. any suggestions on brands? a buddy (who happens to be a ford mechanic) said to only use ford oils.
i'll probably get to it in about 2 weeks, just doing some research. thanks
Old 05-22-2007, 01:43 PM
International Threat
Check out my pix (click on the picture in my signature)... some people say go synthetic and surely that's not a bad idea. I refilled mine with Mercon/Dextron III.
Old 05-22-2007, 01:45 PM
Here's a direct link...
TransmissionService pictures from trucks photos on webshots
Old 05-23-2007, 09:17 AM
How do we get the fluid out of the system if we don't have a TC drain bolt?
Old 05-23-2007, 01:27 PM
Amsoil Universal ATF
Old 05-23-2007, 01:42 PM
If you do the flush every 15k and flush +filter ever 30k then don't worry about the fluid in the TC.
I've heard you can d/c the lines and use some air pressure to move it but I don't do that.
Old 05-23-2007, 02:09 PM
Dieselman77 - What change interval do you recommend for Amsoil Universal ATF?
Old 05-23-2007, 03:08 PM
Good to see diesels running strong down under. I would go 30K then change it but make sure you change the filter to. Don't just flush it.
I'm being a bit conservitive because I don't know how you drive or if you haul heavy loads. 30K would be worst case
