BETTER DRIVE
OK, what can i do to get a better ride/drive on my 99.?? Its got a 5.5 Fab-tech lift, Single shocks. 33" nitto'S. I've change my ball joints and front shocks. But it still seems a little loose. I haven't change tie-rods or sway bars. or changed out my rear shocks. and i just turn 211K on it.
go back to stock..lol
check the sway bar bushings..see how loose they are.. just go over the whole front end. |
Ha ha , thought of that. just won't look the same. How much play should there be if any on the tie-rods? i did notice some movement on those last time i checked. Now the sway bars they seem tight but ITs got 211k on bascily factory bushing etc.......
Sell your springs get stock V and B's and do a hanger lift with correctly valved Bilsteins..
well if i knew what you were talking about i maybe could look into it? V & B? Hanger lift? wtf
V and B codes are stock springs found on the majority of 99-04 SD's with a diesel. You can check the door sticker to check codes. get used or new at ford.
Front hanger lift..4.5" with V code fronts will ride better than any lift spring. Rear for level is a 5" block. You could also if you don't want a tall block use Icon's rear 5" lift spring ..will ride better than stock but will sag more than stockers when loaded towing or hauling. |
I think my rear lift is a tall block (Fab-tech) But it seems like it more of a keeping it on the road ride,,, that i'm speaking of. it just seems to be a bit squerrilly when i hit a rough road. OR I SHOULD SAY A BIT LOOSE on rough ROADS it all over not saying its not a lift thing but i never had this problem b4
You ought to just jack it up on both sides, throw some jack stands under the axle. Then start checking everything out. Heck it could be a bad wheel bearing, you could have bad bushings in the springs, and check out your stock stabilizer...
steering gear may be worn... I am about to replace mine with a redhead
yes. i was thinking same its got play. but isn't there away to adjust. or is it just better/safer to replace?
