i know this was already posted on another year for that my stupid a.. put there but, anyways. i have a 6o innercooler that i just installed and after i had noticed that my boost was low. so i checked everything and put new boats on the innercooler lines and still low boost. is there anywhere else that would make me loose boost. thanks soo much for any input.
turbo up pipes..they leaking?
i have to check. some one else said that. is there a special way to?
nope..is there soot around all the seals..and on the pipes..yes..there leaking lol
mine are leaking..i went from 30psi WOT to 24
well i went from 25 to 12 at wot
There may be a boot leaking connecting the intercooler or the intercooler may possibly be leaking.....the reason being everything was ok until the install of the 6.0 intercooler.....thats my opinion anyway.....let us know what you find, good luck......Fred
i had the same prob low boost but after i turned the truck upside down looking for the problem i finally realized it was the line going from my turbo to my gauge it had a hole in it and wasnt reading right at all replaced it and went back to about 25 or so instead of 10
yea thats what i thought to. then they gave me another one that was tested for leaks and it was good
that was my prob....uppipes dougnut,the chevy ones work great.i was barley regeristing like 2psi,now at wot i see 30 to 35 and throw ces light.i also gutted the pedistal,i can hear the hissing at my gauge it works so well
hey johnboy,the line that was leakin on your gauge.this is what i did,i used the neoprene line that was supplied but i went a step further,i went and got 6 foot of copper line that was one size bigger than the neoprene and snaked the neoprene through the copper,stuck the neoprene on the connector at the turbo,the drilled a hole in the firewal and run about 4 inchs of the copper through the fire wall,and were your pedels are there should be 2 or 3 foot of neoprene,this way there is no neoprene exposed in the engine compartment,only at your feet and in the cab
