So well today I got stuck.. Time to finish this project since i first started this I now have a front axle in and no transfer case or transmission to drive it. So what next i figured those two im really dont wanna go with a man.. due to the issues of installing clutch and devices.. but dunno.. if its not too hard.. also i want a non electric transfer case unless its also pretty easy to install so what kind of options do i have?
I'd buy a totaled gas 2005+ 4x4 and swap everything, and then find a 4x4 tailhousing for your tranny. Plenty of folks have converted to 4wd, you just need to start gathering parts.
And Tank was running 41"s on 4.5" of lift because he had cut-out flares giving him much larger wheelwells. He has a cool youtube video of all the things hes done to that truck. |
Well thats what I wanna do with mine... but not that extreme or maybe exept for the rock crawling .. so an 05 or newer gasser what about the shocks and the springs will they work?
But I'm sure a diesel chassis can be had for cheap also. Also if you go for an 05+ front axle you will need to swap in the rear as well to the correct wheel spacing on the front and back. Thats the only drawback to going with the later model coil axles, but that does give you the chance to run some of the cooler '05-'11 wheels.
and im all stock ![]() if you can find a rolling chassis off a later year model truck.. id just buy it and swap everything..make sure you get something with the same length or youll need to track down diff drive shafts too |
If you run 05+ wheels on a 99-03 wouldnt your wheels stick in a little. I know some people run spacers. But you have no spacers? How does that look?
Ok well What if I go the cheaper route right now and go with leafs... How hard later would it be to change to the 4 link setup i posted? or should i buy the set up and with the 4.5 inch lift and bolt up would that work? Oh and Yeah I knew about the fender flairs I wanna do that too looks mean as hello...
Hey just to bump up my own thread and take up space look at this thread... I just found it even though I replied I forgot about it... This would be the best swap right? At least for now.? I wanna do some of that but I can always ask more questions later.
Here is the thread... 4X2 TO 4X4 Whats the benefits to both.? Last edited by SniperFolf; 07-14-2010 at 04:32 PM. |
look at my sig.. they look good to me..
