Disconnecting Wastegate - Ford Powerstroke Diesel Forum
post #1 of 15 Old 04-15-2006, 07:51 PM Thread Starter
PIPE HITTER
gcop's Avatar
Seems like a read somewhere that is was OK to take off the wategate actuator line and plug it up, because the stock turbo would not make enough boost to harm anthing. True, untrue?
Currently I have only intake and exhaust mods. Gauges will be in next week.
"Life is hard, it's even harder when you are stupid"
gcop is offline
post #2 of 15 Old 04-16-2006, 04:00 PM
RJacks258's Avatar
Mine has been unhooked for a while, and I haven't had any problems. With My TS chip on 140 I can hit 32psi of boost. I haven't quite researched what the 7.3 can handle stock.
'99 Ford F-350 crew cab, dually, 2x4, Banks Monster Exhaust-muffler deleted, Banks Six Gun Tuner, , TS performance 6 position chip stk, Hi idle, 50, 75, 100, 140, Banks Transcommand, wastegate mod, Map Sensor Fix from SP Diesel, Zex Diesel Nitrous kit with purge, bottle heater, and blow down, next step---H2E, need to install- bully dog shift kit, 6.0 intercooler
RJacks258 is offline
post #3 of 15 Old 04-16-2006, 04:53 PM
wesjones's Avatar
i've heard of disconnecting the wastegate but not actually removing it...i have heard of removing the ebpv completely and plugging it: this is supposedly better...
wes
2001 F-250 XL 7.3 PSD, 5" MBRP Turbo-Back Exhaust, K&N FIPK Intake...
wesjones is offline
post #4 of 15 Old 04-16-2006, 07:33 PM Thread Starter
PIPE HITTER
gcop's Avatar
I should get around to the gauge install in he next few days, I'll give it a try then, at least I'll be able to check on EGT's just be safe.
gcop is offline
post #5 of 15 Old 04-17-2006, 07:05 AM
RJacks258's Avatar
I've read on the ebpv mod also. I just didn't want to spend the time.. When I remove the stock turbo to replace it I'll remove the valve.
post #6 of 15 Old 04-17-2006, 07:08 AM
RJacks258's Avatar
You can also mod the ebpv into an exhaust brake. There are threads on that also.
post #7 of 15 Old 04-17-2006, 09:26 AM
red97's Avatar
could you tell me where I could get more info on that.
red97 is offline
post #8 of 15 Old 04-17-2006, 05:04 PM
RJacks258's Avatar
More info on which one?
post #9 of 15 Old 04-21-2006, 10:00 AM
red97's Avatar
changing the ebpv valve into a exhaut brake
red97 is offline
post #10 of 15 Old 04-21-2006, 05:07 PM
RJacks258's Avatar
I can't find one on this forum. I'll do a search sometime tonight, I know there's one somewhere I just have to find it. When I do, I'll post the link for you.
