How Big of a tire can i fit on a stock 99 crew cab? - Ford Powerstroke Diesel Forum
Old 05-19-2007, 11:55 AM
Hey Guys, I am thinking about getting some bigger tires for my 99 crew cab 4wd , since I have determined that it may be a while before I can lift it. So, the question is, what size tire can I fit under a stock truck? Thanks for the help..
adam
Old 05-19-2007, 11:57 AM
4wd you can go with 305/70's, although I've seen some folks run 315's and they just barely rub. not sure on 2wd If I had a 4wd I'd just put on a leveling kit and some 35's or 315's
Old 05-19-2007, 11:59 AM
I believe 285/75/16 fit nice with no rub. I have 315/70/17's with 2" add-a-leafs on all 4 sides, but they rub a little.
Old 05-19-2007, 12:04 PM
I had 305/70's on my 02' 4x4 and they didn't ever rub
Old 05-19-2007, 01:32 PM
Feedback Score: 5 reviews
I've got 275/65R20's on my ex cab lb 4x4, no rub. That size is 34" tall.
Old 05-19-2007, 01:35 PM
i believe 315's will rub.. im running those right now with a 3.5" shackle leveling kit.... if your interested in a leveling kit let me know and ill get you a good deal on one....
Old 05-21-2007, 07:55 AM
Thanks for all the info guys. I am sure that I will need a leveling kit for now. I have seen some on ebay for under $100. Not sure if that is good or not. 7.3pwrstroke what did you have in mind?
Old 05-21-2007, 08:06 AM
i ran 315 bfg muds with stock lift and only rub when you turned the wheel all the way then i put on a leveling kit and they dont scrub at all but i do have the stock rims
Old 05-21-2007, 09:32 AM
I have seen 35's on a stock truck, but a 33 is prob. better
Old 05-21-2007, 07:56 PM
Send a message via MSN to papabear
tire size
go to the skyjackers website and it will tell you that's the best advice i can give you
