Dyno Results
So I managed to get on a dyno and I'm not to thrilled with the results(probably cause all the dodges laying down some monster numbers!)
I think they are decent for power to the ground. I don't know. Let me know what y'all think Dyno Sheet It's kinda hard to see the last two runs. What I don't get is on my ts I made more power on the 100 setting then on the 140. Blue was stock setting. |
You don't have all the necesary supporting mods to run the 140 tune to it's potential.
I dont know anything about the 7.3's but it seems low for the mods you have, and im like you, why did it make lett hp on the 140 setting. Also i thought that the 100-140 hp setting was suposed to make that much more hp at the wheels. Maybe im still a newbe
Dropping too much HPO with the TS tunes, get a better chip and you'll get better #'s. Other than that, I don't know you have solid mods on your truck, so that's what leads me to thinks it's just the chip. I probably shouldn't even ask but you ran single rears on the dyno right?
no I kept the duals on. I think you're right about the chip. I think the TS is hurting more than helping. With the hundered horse I was only 60 over stock. I know it's not a true 100 to the wheels but I figured i would of had better stock numbers!
Your spinning a lot of wieght with those duals. Pull the outside wheels and you'd pick up a few HP i would bet.
what about boost leaks? might be something to check. Don't stock 7.3 powerstrokes make around 170-180rwhp? I would think you would be in the 260+ range with your mods. I may be wrong though
I don't have any boost leaks. I have an exhaust leak at the up pipes for the turbo, but I think my hpop is getting weak.
those numbers seem way too low.... i have about the same setup as you except im running the edge stuff and made over 300 hp and 600lbs of torque...
I wonder if the exhaust leak could be robbing horsepower. I don't know what else to check. Guess I need to take it to a dealer and have them check the hpop and injector pressure. I'm with you Raul I'm thinking I should have bigger numbers.
