Changing to synthetic motor oil at 100K
Hello, I have apx. 100k on my 02 7.3. All its life I have run Delo400 and I was thinking about switching to the mobil 1 diesel oil they just came out with. Are there any negatives that could occur if I do this switch so late in the game?
In a gas engine I would say don't do it due to risk of leaking.. I'm an amsoil dealer and have had customers switch at over 200k in their diesels with no problems. Go ahead with it!!
Using Synthetic oil (AKA) non petroleum, from the start will eliminate sludge wich eliminates seal leakage. :whistle: |
Yes petro does form a AKA Seal around the seals, but diesel have a much higher detergent in them than Gas oil does, and what causes petro oil to do that? Do Diesel dino co ntain a high quanity of this? I know where your getting at I have been around for long enough. Also I have had Many many customers switch to amsoil well after 100k in a gas engine. I advise them not to use the engine flush and have never had a customer with a seal leak.
Hell I even have a newer customer that started using it in his 97PS with over 300k on it with only rave reviews from him. I'm not saying it's a myth but I wouldn't worry as much as everyone claims this happens, it usually isn't the case |
are you saying diesel dino does not make sludge? cause I would have to disagree. I use engine flush with any vehicle with over 50,000 miles with Dino oil, this is because in the first 5,000 miles it will use half as much Amsoil to clean out the engine than not using the cleaner. usually it uses 2 quarts in the first 10,000 miles and the next 15,000 miles it uses none. this is with well maintained engines of course, many with over 100,000 miles with AKA sludge oil |
I think over the years in all the advances in synthetics from day 1 have eliminated the problem of certain sealing materials leaking when switching from dino to synthetic - from what I've read.
You're fine to switch at any point in time, and switch back and forth as you please IMO. We have an 86 Bronco II that switched to Amsoil, previously just about every on-sale dino motor oil you can find it's goten for changes, no leaks and nothing out of the ordinary out of the few months it's had Amsoil in it. |
Converting From Petroleum Motor Oil To Synthetic Motor Oil
Q. Is it true that installing AMSOIL or other synthetic oils will cause my engine to leak oil? A. In modern vehicles, there is no risk of AMSOIL motor oil leaking. In fact, AMSOIL motor oil is fully compatible with modern seal materials. It is properly formulated to condition seals, keeping them pliable to prevent leakage. As I stated it will not cause your engine to leak. |
