Scheduled maintenance? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 05-17-2007, 03:23 PM Thread Starter
CattleHauler's Avatar
Well I know it's time to change my oil and filter so...what oil and filters do yall prefer on your PSD?...Also, my truck has 165,000 miles, what other scheduled maintenance should I be doing with that kind of miles? I'm trying to keep the ol' truck running good
Thanks
CattleHauler is offline
post #2 of 9 Old 05-17-2007, 03:32 PM
Thats Mr. Oil Leak.....
MrJohnWayne's Avatar
Quoted: 5 Post(s)
I use rotella 15w40 and napa gold(wix) filter.
If you have never you might want to check your serpentine belt, ilder pulley, tensioner assy, and coolant hoses. Probably wouldnt hurt to flush your coolant system either. Do you have an auto or manual. 2x4 or 4x4. Probably would hurt to change the fluids in the front and rear ends and tranny. Although if you have an auto and never changed the filter/fluid I would not recomend doing it now. Check your ball joints and wheel bearings. you can do that by doing the shake test. Probably would hurt the grease the front end while you are under there.
Just a few things I can think of.
John Wayne
Owner and Operator of the
REDNECK VALDEZ
You can find me on
MrJohnWayne is offline
post #3 of 9 Old 05-17-2007, 03:41 PM Thread Starter
the trucks a manual and 4X4...thanks, I appreciate all the help so far
post #4 of 9 Old 05-17-2007, 03:55 PM
Quoted: 5 Post(s)
Good deal man. Get some pics up so we can see it!
John Wayne
REDNECK VALDEZ
You can find me on
post #5 of 9 Old 05-17-2007, 04:32 PM
sldghamr's Avatar
don't forget your thermostat!!! i have a 96 PSD and my thermostat is about $40 at the Fraud dealer.
if you see a light at the end of the tunnel, it's probably just a photon torpedo
sldghamr is offline
post #6 of 9 Old 05-19-2007, 04:46 AM
Lord Tauk's Avatar
Fuel filter probably wouldn't hurt
Lord Tauk is offline
post #7 of 9 Old 05-19-2007, 05:49 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Air Filter as well. on that use anything but K&N
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #8 of 9 Old 05-19-2007, 06:26 AM
Rob
Rob's Avatar
Quoted: 2 Post(s)
I use the Rotella 15W40, and stay with the factory Motorcraft filter.
Audentes Fortuna Juvat
(Fortune Favors The Bold)
The Org. Staff reserves the right to
move, modify, delete or merge threads/posts
at our discretion, without explanation
at any time.
Rob is offline
post #9 of 9 Old 05-19-2007, 07:26 AM
Purolator makes excellent filters: Premium oil filter is about $18.95 @ Autozone. Heads up on Fram air filters: If you are changing the stock unit, the Fram is $89.95 but the STP is $74.95. The Diff? None except for Fram's fancy box. Both have the same P/N tag with identical #s on the body (made by Purolator I think).
Damichi is offline
