The drips - Ford Powerstroke Diesel Forum
post #1 of 3 Old 05-17-2007, 02:01 PM Thread Starter
powerstrokindad's Avatar
The drips
How difficult is it to replace the pinion seal on my truck? Its been leaking for a while and its time to take care of it. Any thoughts??? Rod
2000 F350 Extend Cab ZF6 DRW 2WD
*Edge Juice*FBD 4" Exhaust dumped in front of rear axle*6637 intake*ZooDad Mod*CCV Mod*BD X-Monitor*DIY Map Fooler*Rebuilt Turbo*Banks Big Wheel*Tighted WG Actuator*EBPV Delete*Cleared Light Covers*Foil delete
Towin a 42' Franklin 5er with triple axle's and a 5th wheel to gooseneck adapter, grossin about 16000 lbs.
powerstrokindad is offline
post #2 of 3 Old 05-17-2007, 03:03 PM
Thats Mr. Oil Leak.....
MrJohnWayne's Avatar
Quoted: 5 Post(s)
not hard at all. Remove the driveshaft off the pinion yoke. Remove the pinion nut. Can't remember what size it is and it will be tight! A puller will be your best bet removing the yoke. You don't want to beat it with a hammer cause you can weaken it. pop the old seal out. Put the new seal in. put the yoke on. Here you can use a block of wood to place on yoke the tap the yoke on. the wood will absorb the impact. put the nut on which can also be used to draw the yoke down. Torque the nut (can't remember the spec) and replace driveshaft.
John Wayne
Owner and Operator of the
REDNECK VALDEZ
You can find me on
MrJohnWayne is offline
post #3 of 3 Old 05-18-2007, 04:13 PM Thread Starter
That is about what i thought, but just wanted to be sure...thanks, Rod
