fuel gauge not working - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-14-2007, 07:35 AM Thread Starter
i noticed that my truck shows thats is full all the time i have no idea what could be wrong im new to diesel please help thanks
jcurtis is offline
post #2 of 4 Old 05-15-2007, 12:56 AM
im fat and ugly
stump0331's Avatar
it may be that the floats are stuck in the tank
2004 Excursion
stump0331 is offline
post #3 of 4 Old 06-10-2007, 11:30 AM
straycat's Avatar
Hey jc, I moved this for you so you will get a little more action on it, there could also be a problem with the grounds to the tank causing the problem, you might want to check that.
Gord.
SKILLFULLY DISGISED AS A RESPONSABLE ADULT.
99.5 F350, CC, LB, DRW.
7.3 AUTO 4.10s
AUTOMETER C2s EGT, TRANS, BOOST, OIL, FUEL PRES
ATS, WW, SSHPX, B ANNIH.
DP 6P 140EX.
AFE MAG F STG 2.
MAGNAFLOW 4'' TURBO BACK DUALS.
US GEAR SUPER D-CELERATOR
500LTR FUEL TANK
BILLET GRILL
ALARM & REM START/ ELC BAT DISC.
CB, SAT, GPS, PANASONIC CD, 5th WHL
35' GOLDEN FALCON
Been a mod longer than TJ hahaha
straycat is offline
post #4 of 4 Old 06-10-2007, 02:59 PM
Just repaired my fuel guage problem, same thing, stuck on full. It wasn't the fuel sender but the wire connector to the fuel sender was bad. Just replaced the connector and it works fine. If I remember correctly, there was a yellow wire that was corroded badly inside the connector and when I wiggled the harness the yellow wire just popped off. Give it a try, its definately better than replacing a sending unit in the tank although they are a common problem as well.
grabowskimech is offline
