Roar Noise From Front End 4x4 Auto Hubs? - Ford Powerstroke Diesel Forum
post #1 of 31 Old 05-13-2007, 11:20 AM Thread Starter
PearceTrucking's Avatar
I Use My 2002 F350 4x4 Psd For Hauling Boats And Boat Trailers. I Usually Gross Right Around 20,000 Lbs Sometimes 22,000. When I Am Loaded With A 32 Ft Haul Trailer With 6 Trailers Stacked On It And 2 Trailers On Top Of My Cab On A Special Made Rack, I Get A Roaring Noise Out Of What Seems To Be The Front End. The Noise Comes And Goes, Maybe Every 20 Seconds Or So. I Know For Sure It Is Not Tires As I Replaced The Tires With New And It Made No Diff. I Dont Know Why, But I Feel Like Maybe My Front Hubs Are Tryiny To Engage My Front Halfshafts, Or Maybe My Transfer Case Is Trying To Spin The Front Driveshaft?? The Truck Has The Auto Locking Front Hubs. I Keep Wanting To Think That The Carrier Bearing Is Going Bad, But I Drive About 2400 Miles A Week On Average And It Gives Me Lots Of Time To Try To Determine Where The Noise Is Coming From And It Sure Seems To Be Coming From The Front. Also, When It Is Making The Roaring Noise, I Can Feel Some Light Vibration And I Feel It Most In My Feet (the Floorboard). What Kinds Of Things Can I Do To Help Diagnose What Is Going On? When I Am Empty With Just The Empty Haul Trailer You Dont Notice It As Much, And When I Have No Haul Trailer You Can Barely Feel-hear It But It Is Still There. It Is Getting Worse Though With Each Load, I Just Took A Load This Week From Illinois To Long Island New York And I Was Starting To Worry About Breaking Down. Have Any Of You Ever Heard Of Such A Thing? Can The 4x4 Auto Hubs Try To Start Engaging The Front Axles When Loaded Heavy Even If You Are Not In 4x4? Or Could This Be Something Completely Different? Thanks In Advance For Your Help!
PearceTrucking is offline
post #2 of 31 Old 05-13-2007, 11:28 AM
duct tape & zip ties
bigcountrysg's Avatar
Are you sure your not hearing the fan working when the fan clutch engages and locks up and spins the fan. That gives a loud roar noise. Which is normal.
Your Actions Today, Decide Your Future Tomorrow
2005 6.0 Crew Cab Long Box Lariat, current truck
2004 6.0 destroyed by contaminated fuel
2002 7.3L burnt
bigcountrysg is offline
post #3 of 31 Old 05-13-2007, 11:44 AM Thread Starter
Hey there, no that is not it, I can hear the fan when it kicks on and off (especially when I have the A/C on) this is certainly drivetrain related.
post #4 of 31 Old 05-13-2007, 11:48 AM
Ok just checking because some people hear that fan and get scared that something is wrong.
With what your describing it sounds like the carrier bearing or U-joints then. I had the same problem with my 2002 it lasted for about 20,000 before the carrier bearing exploded. Then I had to remove the driveshaft and limp home in 4wheel drive. Using the front end only.
2002 7.3L burnt
post #5 of 31 Old 11-14-2009, 08:57 AM
merc123's Avatar
Any resolve? Mine is doing the same thing and it feels like its in the front
merc123 is offline
post #6 of 31 Old 11-14-2009, 10:43 AM
Leeville Outlaw's Avatar
I think ur inner bearings that hold ur axle in center are probably gone on going out. My truck did the same thing. Can u move the axle up n down a fair amount where it comes threw the frontend to the hub where the u joint is if so thats where ur problem is.
Leeville Outlaw is offline
post #7 of 31 Old 11-14-2009, 10:53 AM
merc123's Avatar
This thing? If so, it has a lot of play and passenger side has none. What's involved in fixing it?
merc123 is offline
post #8 of 31 Old 11-14-2009, 11:20 AM
Tony V's Avatar
I just had those in my truck replaced and fix them if they have a lot of play before they stop working. Your steering and all will mess up.
2000 F-250 216k- smoke much?
Facebook: Anthony VanCamp
Add me if you'd like
Tony V is offline
post #9 of 31 Old 11-14-2009, 11:21 AM
merc123's Avatar
Truck is parked until I can get it fixed.
merc123 is offline
post #10 of 31 Old 11-14-2009, 11:59 AM
my hub assembly was good but the bearings the axle rides on were gone and the plastic cap that holds the axle in center had melted. Instead of having to replace the hub assembly which is around 300 i went to oreillys n they had the bearing that is inside the hub n i replaced that then I had to buy another locking assembly to replace the outside axle bearing n plastic cap. n all i spent 110 to get it back going
