Smoke? - Ford Powerstroke Diesel Forum
Old 05-12-2007, 04:33 PM
Smoke?
With my mods shouldnt i see some smoke wheel i get on it? i thought the 10k mod would generate a little. the side of my truck turns black after a couple of weeks without washing it. i just dont see it. let me know what you guys think...Rod
Old 05-12-2007, 05:37 PM
the 10K will only give you a little poof of smoke, drop your resistor to a 5.6K or a 3.9K that should give you enough to make you want a tuner or chip :burnout
Old 05-12-2007, 06:26 PM
monday i will hit up radio shack and get an assortment of resistors and play with different ones. i read on here some where that different trucks like different resistance...Rod
Old 05-12-2007, 06:37 PM
anything lower than a 10K will make your idle go to crapp , but some folks like it.
Old 05-12-2007, 06:40 PM
mine is a little rough but no to bad...will shimming fuel regulator help with smoke?
Old 05-12-2007, 06:45 PM
I shimmed mine and all I got was 3 bad fuel pumps. although that and the intank mods will quiet and smooth out the engine to some degree.I wound up going with the external reg fuel system from ITP.
Old 05-12-2007, 06:50 PM
you should really think about getting a tuner, I have the DP tuner and when I put that thing in the holy s%&# mode she smokes like a cuban cigar.
Old 05-12-2007, 07:34 PM
Dieselis' Maximus
I say get a Tuner also. When i want to smoke i just turn up my DP chip.
Old 05-13-2007, 05:29 AM
a tuner is definately in the works, but we just got back from a 7 day cruise and that took my extra stash... tryin to get it built back up so i can keep playin. i just thought i should see some smoke now...Rod
Old 05-13-2007, 08:26 AM
or you could go with the ts chip like i have it will give you all the smoke you want plus you can get them for cheap if you search around.
