emergency brake not working...failed inspection
OK so I failed my PA state inspection because my emergency brake isn't working. I said I wanted to look into it before they fix it. What am I getting myself into???? Any links with pictures? How hard is this? Is it not worth my while? If I should just get someone else to do it...how much would I be looking at (how many hours do "the books" say it should take?)
Thanks. |
My only experience with E-brakes have been the cable kind. So there is just a cable that gets pulled when you pull up on the e-brake handle which then clamps the brakes. Shouldn't be extremely hard to troubleshoot or fix I wouldn't think. But I haven't done one on a F250 so maybe i'm completely off?
it isnt too hard, most likely you will need to replace the park brake shoes, maybe the rotors(cuz the drum for the park brake is a part of it) The tip off on the drum is a deep ridge on the outer edge. The best way to get things adjusted is to crank out the adjusters till you can just barely get the drum/rotor back over the shoes. It the drums are worn too bad the ridge makes it pretty hard to get them to tighten enough to hold the truck.
confused yet? |
you will have to ramove the wheel, then take the axel out. Then the large ratcheting nut which is(inside the axel area, it uses a special tool(socket) to do it). Remove that, then the hub comes off. You will see the e brake shoes then.
YOu might as well replace the axel seal and axel O-ring while you are at it. I believe the torque spec on the ratcheting nut it 60 pounds then back off 5 clicks. |
