Injector Control Module Low code - Ford Powerstroke Diesel Forum
Old 05-30-2010, 06:41 AM
2002 7.3 with a 189k miles on it idled erractically then threw a code this am engine light then came on , on the computer it said Injector control module low was told it could be a loose wire in the harness, The code and idleling corrected itself then acted up again, with the truck running I checked the wires and wiggled them all didnt get it to act up again then this am again stopped at the light engine light came back on then idle rough but not as bad as before,,, now what? would a injector thats starting to go do this ?
Old 05-30-2010, 07:03 AM
Ok had my buddy run the comp. again on it it says " Injector control signal circuit out of range low" then running the numbers its shows ICP 0.00 then it jumops to 0.01 then back to zero The injector control pressure is 725 and Inj pressure 14 Pcode 1280 where can I find the Injector control module? and would loose wires under the valve covers caused this before I remove them and check it
Old 05-30-2010, 07:28 AM
DC2 DIAGNOSTIC TROUBLE CODE (DTC) P1280
DTC P1280 indicates injector control signal circuit out of range low was detected during KOEO Self Test or during continuous diagnostic monitoring.
Possible causes:
biased ICP sensor/PCM
open ICP sensor circuit
short to SIG RTN or PWR GND on ICP sensor circuit
open in VREF circuit
Make sure the wires on the large square connector on the left valve cover aren't chaffing on the valve cover
Key on engine off ICP voltage should be around .3 Volts and pressure should read Zero Psi..
Old 05-30-2010, 07:48 AM
I did check the wires on the left side the valve cover they were rubbing but when i removed them and turned them upside down to see underneath they looked fine i taped them up any way , could it be the ICP sensor? I know to unplug when its running rough to see if that changes the engine but its intermiitant and runs rough usally at a light this just started happening yesterday. are the reading i have wrong?
Old 05-30-2010, 08:08 AM
i'd bet ICP sensor is bad.
Old 05-30-2010, 08:22 AM
Mine did the same thing, turned out to be a oxidized pin on the ICM located up inside the drivers fender, had to remove the inner fender well to get to it, removed the connector, cleaned it up, and put it back together, been working for 7 months now.
Old 05-30-2010, 11:20 AM
is there a sure way to test the ICP sensor?
Old 05-30-2010, 04:02 PM
update... after reading all day I checked a bunch of things behind the HPOP the IPR valve has a wire connector where the two wires go into the plug they were worn, exposed and touching each other copper to copper I temp fixed for now by sliding a bigger wire sheathing over them until i can buy new connector harness and i also checked the ICP sensor cleaned all the oil inside the connector itself after i started and checked the icp again it still had oil inside the three little prongs so im assuming bad icp,,,, also seems to idle alot better now im assuming b/c the IPR valve is operating properly
Old 05-30-2010, 06:39 PM
addicted to diesel
ya if the icp has oil in it, its safe to assume replacement is a good thing.
Old 05-31-2010, 02:10 AM
