Bypass filter question - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-28-2010, 01:28 AM Thread Starter
DJM
DJM's Avatar
I have an fs2500 bypass filter and my question is I have the return line going into the hole were you check to see if you have PMR's or not does that port have suction there? My oil doesn't seem to stay any cleaner than before thats why im asking.
2001 Crew Cab, Auto
6in lift, 37Toyo's
DP F6 60eco,80tow,80eco,120
Wicked Wheel
Foil Delete
Isspro EV2 Guages
HPX Line
RiffRaff FRx
4" Exhaust
AFE Big Boost
FS 2500 Filter
DJM is offline
post #2 of 4 Old 05-30-2010, 02:55 AM
ACC
A bypass filter will not keep your oil from sooting up and getting black, those soot particles are sub micron and no bypass sytem that I know of will clean it out of the oil.
That bypass system you have will protect your engine from the larger particles that do the real damage, it's a good investment if your going to keep your truck for a long time.
Tom
95 F250XL PSD SuperCab, BTS E4OD with a 6.0 31 row cooler, TS 6 position with Gearhead Tunes, Downpipe, Vegistroke V3, Tymar Intake, Autometer gauges, Gutted EBPV, Tymar Coolant Filter, Crystal Headlights, AC Mod, OilGuard Bypass, Stage 1's, Adrenaline HPOP, 370k and still Smokin.
Early 99 XLT SuperCab Auto, 4" Exhaust, DIY Tymar, Autometer Gauges, PMT2 ECU
ACC is offline
post #3 of 4 Old 05-30-2010, 05:17 AM
nightstalker's Avatar
if you have alot of miles, you have build up in the motor, thats natural in any combustion engine, particularly diesels, the fella above is dead on. Did you do the engine flush prior to installing the by-pass?, I have heard and seen some good results from Amsoil engine flush( if you want some info, let me know) i havent used anyother kind of engine flush so i cant speak as to how they work. good luck!!!!
nightstalker is offline
post #4 of 4 Old 05-30-2010, 11:46 AM Thread Starter
DJM
DJM's Avatar
Shoot me the ifo I never heard of it. I have heard of runnin ATF thru the motor and draining it. I got 157k on the truck
2001 Crew Cab, Auto
6in lift, 37Toyo's
Wicked Wheel
Foil Delete
Isspro EV2 Guages
HPX Line
RiffRaff FRx
4" Exhaust
AFE Big Boost
FS 2500 Filter
DJM is offline
