fuel pressure question - Ford Powerstroke Diesel Forum
post #1 of 13 Old 05-26-2010, 01:51 PM Thread Starter
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
on my truck, I have a fuel pressure guage inside the cab. when I am running down the road, it reads anywhere from 50-60 PSI. I have no mods done to the FP regulator. After shutting the truck down, the guage will drop(over time) to 0 PSI. Is this normal? or should it hold pressure till the next time I get in and drive it?
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #2 of 13 Old 05-26-2010, 07:58 PM
no-tel-in's Avatar
nope, thats normal. Key off the pump shuts off and it will lose pressure
2000 F-250 4x4 7.3
BTS Transmission - 6.0L Cooler
GTP38r
Full Fuel System with Return
2-Stage W/M & Nitrous
Adrenaline HPOP
238/100's
no-tel-in is offline
post #3 of 13 Old 05-27-2010, 03:46 PM Thread Starter
Doesn't Even Care
Quoted: 69 Post(s)
thats what I thought. Then I dont have an issue. thats awesome!!
Nick
"The Mistress"
post #4 of 13 Old 05-27-2010, 03:51 PM
Mikey's250's Avatar
How important is a fuel pressure gauge? What will I be able to monitor from it?
Mikey's250 is offline
post #5 of 13 Old 05-27-2010, 03:58 PM Thread Starter
Doesn't Even Care
Quoted: 69 Post(s)
I put it in to monitor when I had Fuel pump troubles. all it shows is what fuel pressure you have at the bowl.
Nick
"The Mistress"
post #6 of 13 Old 06-25-2010, 06:41 PM
99BEIGEPOWERSTROKE's Avatar
Can you tell me how you put a fuel pressure gauge in your truck? Is there a kit you can buy somewhere for it?
1999.5 FORD F250 SUPERDUTY 4X4 EXT CAB
7.3L POWERSTROKE DIESEL
6 SPEED
SWAMPS 175/146 SINGLE SHOT INJECTORS
SWAMPS TUNING
6" AUSSIE STACKS
AFE INTAKE W/ PRO GUARD 7 FILTER
VAN TURBO
4" SUSPENSION LIFT
315/75/16 BUCKSHOT MAXXIS MUDDER TIRES ON STOCK WHEELS (WINTER TIRES)
16X9 MOTO METAL 951 BLACK WHEELS (SUMMER)
COWL HOOD
99BEIGEPOWERSTROKE is offline
post #7 of 13 Old 06-26-2010, 11:27 AM
Let's go B's!!!!
Southpaw's Avatar
Feedback Score: 5 reviews
IIRC you should be at about 65 PSI all the time Nick. It should be the most boring gauge in the truck because it should never move unless there is an issue.
Chris
2002 Crew Cab Long Bed
4" BDS, 35x13.50 Cooper STT on 20x10 Black Rockstars, and other stuff.....310,000 miles and counting...
2 Thessalonians 3 v.6-15
Southpaw is offline
post #8 of 13 Old 06-26-2010, 01:16 PM
tubular031's Avatar
Not with a stock fuel pump. they will hold 50+ but will not keep it up at 60 when you floor it. pulling my 5er my stock pump makes the gauge dance all over. with my fass pump on the VO side it sticks rock solid at 70 and does not more from idle to WOT grossing 22k.
Most agree that 50+ is fine.
Just a basic 01 F350 CCLB SRW -Good from a far but far from good
tubular031 is offline
post #9 of 13 Old 06-26-2010, 01:17 PM
tubular031's Avatar
Fuel Press
then hook up whatever gauge you want to use.
post #10 of 13 Old 06-26-2010, 01:20 PM
If I had a small leak from the fuel bowl lid would the fuel pressure be low?
6 SPEED
SWAMPS TUNING
6" AUSSIE STACKS
VAN TURBO
4" SUSPENSION LIFT
COWL HOOD
