muffler blocked up? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 05-24-2010, 04:55 PM Thread Starter
jonnydiesel's Avatar
muffler blocked up?
can the stock muffler get blocked up my egts are higher then normal. i havent changed anything i do. a guy up the road from me said his dodge had that problem at it was his muffler
jonnydiesel is offline
post #2 of 8 Old 05-24-2010, 05:02 PM
atvrider93's Avatar
Quoted: 8 Post(s)
not usually a muffler unless it basically rusts out. a cat would be more likely
atvrider93 is offline
post #3 of 8 Old 05-24-2010, 05:31 PM Thread Starter
i have a cat less truck. my local diesel tech. told me it could be the muffler too. he said get highflow muffler or straight pipe it
post #4 of 8 Old 05-24-2010, 06:13 PM
if you have the stock muffler you have a major exhaust restriction! straight pipe it.
Dietoremain is offline
post #5 of 8 Old 05-24-2010, 06:21 PM
atvrider93's Avatar
Quoted: 8 Post(s)
maybe I should have looked at the section this was in. ya, straight pipe
post #6 of 8 Old 05-24-2010, 07:21 PM
I was actually wondering this same sort of thing. I have an early '99 with a cat and have noticed higher and higher EGT's over the past couple of months. It's not running as well as it had in the past, either.
I am leaking some boost around the intercooler up pipes to, which I'm sure is contributing to the higher EGT's.
Anyway, just thought I'd comment. I plan on cutting the cat and muffler off of mine anyway in the very near future. Hopefully that improves things for me.
Early '99 Supercab/Longbed 4x4 F-250
276k miles and counting...
Superchip Programmer, DIY Intake, 4" straight pipe exhaust and Transmission/EGT/Boost gauges.
JHALL is offline
post #7 of 8 Old 05-24-2010, 09:11 PM
F250 Fever's Avatar
Send a message via Yahoo to F250 Fever
is you or your truck from california?
2000 7.3 F250 FX4 ext cab short box
Cobalt Pillar Trip pod gauges, trans temp, boost, pyro
4in down pipe to a 5in tip
KnN intake
Tuned by PHP
Banks big head waste gate
6in Pro comp lift
Mag hytec tranny pan
Diablo predator programmer (used for pulling codes)
Foil delete
ATS Turbo housing
Halo projector headlights
BUILT TRANNIE-
Euro taillights
Radar detector
Window tinted 20%
F250 Fever is offline
post #8 of 8 Old 05-25-2010, 04:13 AM
I live in Kansas, and the guy I bought the truck from lives in Kansas, and I'm pretty sure the original owner is in Kansas (but I could be wrong on that one).
I'm not sure where the truck was born though.
JHALL is offline
