issue w/a/c. hot NOT COLD - Ford Powerstroke Diesel Forum
post #1 of 2 Old 05-24-2010, 09:07 AM Thread Starter
ARMY MOM!!!!
korg70kbc's Avatar
Send a message via Yahoo to korg70kbc
Question issue w/a/c. hot NOT COLD
k, have a a/c issue, there is NONE! blows hot air, where do I start? I can hear a 'leak' (or not) under hood after shutting down, but that may be normal, don't know cuz I don't typically listen to that
any clues, want to fix b4 it gets hot again, being a 7.3, HAVE to roll up windows to talk to anyone, YES< I IGNORE LAW!! actually, I don't anyone w/me can't hear, thats how I discovered a/c issue, I RARELY use a/c,
Laurie
SOLD NCHornet's CCV MOD!, stancor GP relay, zoodad, 6637, fumoto valve, 4" turbo back no cat/muffler, Autometer gauges, & AE avail.
korg70kbc is offline
post #2 of 2 Old 05-24-2010, 09:31 AM
MONSTER_NRG's Avatar
Look into this
Originally Posted by powerstroke_n View Post
I got this info from a member on another site and it worked for me. Maybe it will help you and other members out as well. It's worth checking.
You have a classic case of the air gap in your compressor having worn too wide.
Try this to test:
Turn on the A/C and run it until the clutch won't re-engage. Be REAL CAREFUL now! Take a plastic screwdriver handle and "tap" the end of the (not spinning) clutch. Does it immediately engage and operate normally until it next cycles off, and then won't re-engage on its own?
If so:
Get out your feeler gauges, or your calibrated eyeballs, and determine that the air gap is about .050" to .060" (fifty or sixty thousandths). That's too much! It's supposed to be around .030. But wait! There's no need to replace the compressor and have to re-charge the system. There's a "dirt-cheap" fix!
See the little bolt right in the middle of the compressor shaft? Take it out. You won't be letting any Freon out. Pull the clutch plate straight out. There is one or more "shims" that look like small washers in there, either on the end of the shaft or down in the hole that fits on the shaft. Take off about .030" worth of them and reassemble. Go ahead, use a little blue (NOT green!) Loctite on the bolt as insurance.
Make sure you now have at least .025" of gap. Start the engine and check to insure your problem is gone.
That's all there is to it.
I have the same problem but mine works fine for sometime and then just cuts out. If i turn it off and wait 5 min and try it again it work. just seems to go in and out.
SOLD99.5 CCSB SRW 4x4 Lariat Matt@Gearhead tunes, 160cc/80% injectors, New JasperTrans w/ BTS V.B., ISSPRO Gauges, 5"MBRP, Wicked Wheel, S&B Intake, Custom Traction Bars, 6"Lift 38x15.5x r20"tires, Bilstien5100, Foil Delete, CCV & Zoodad Mod, Dual Stabilizer, etc
OUTLAW DIESEL PERFORMANCE
Black 09 SCSB 6.4 Larait Plus Fx4 pkg
MONSTER_NRG is offline
