4in lift - Ford Powerstroke Diesel Forum
Old 05-21-2010, 08:52 AM
4in lift
I am fixin to lower my truck down to a 4in lift for better mpg and also for work and college. My truck is running a 6in lift right now. so all i have to get is new leaf spring packs for the front and the rear has a block so i want to get rid of that and get just leaf spring for the lift in the rear. Where could i get just the leaf spring packs for a 4in lift front and rear? is there anything im missin, all i got to change is the leaf springs right?
Old 05-21-2010, 09:11 AM
and get an alignment after. good to go.
Old 05-21-2010, 09:42 AM
Would i need new shocks?
Old 05-21-2010, 10:15 AM
Feedback Score: 5 reviews
You don't need a alinement, shocks maybe if you don't have at least 3.5-4" of up travel left..Best riding will be hangers and stock SD V codes. Should be able to just remove your taller blocks and use a 5" to be level or 5" rear springs and no blocks. Your Pitman arm may be to much drop for a 4" also swaybay drops, drop pitman bracket...May be cheaper to sell your kit complets and get all new.
Cary
Old 05-21-2010, 10:27 AM
i bought my truck with the lift already on it, so its hard for me to tell which parts have been replaced or came with the lift kit.
Old 05-21-2010, 10:31 AM
i am having a 4 inch put on mine now, would be nice to swap lol then i would HAVE to come up with some new wheels and tires instead of running 35s on my lariets
