Add a leaf
Anybody hear know if the add a leaf that fits on a 4X4 truck will work on a 2 wheel drive truck?? I'm looking to add this in the front but most places I find that have the item at a reasonable price is for a f250 4X4! SO will it work on mine or should I keep searching for the particular one that says 2 wheel drive?
The 2wd trucks are coil up front, they dont have leafs. You would need longer coils.
So where do I get those from? Is it simply called longer coils??
I dont know, when i had my 2wd i went with the cheap method (so i thought) i bought the coild spacers from auto zone. They are actually called "knuckle spacers" which keep the coild from colapsing all the way. I put 4 on each side. It raised it about 2 inches. But then the tires started to wear on the outside, so i had to buy offset ball joints which cost me more than just getting a right lift would have!
Just going to have to go with smaller tires lol
No, just need a kit like this. THey are easy to install.
Ford F250/F350 2" Front Spacer Lift Leveling Kit (w/ Extender Studs) 2WD 1999-2010 -- Fat Bob's Garage Online Store |
And here is a full lift, 6'' in front and 3'' in the rear.
Pro Comp Suspension Systems K4020B - Pro Comp 2WD Suspension Lift Kits - Overview - SummitRacing.com |
Notes:
Truck will need aftermarket camber eccentric to be alligned properly. Camber eccentric's are available through most alignment shops Will I need to re-align my truck after adding these? |
You may need a coil spring compressor? They have them you can borrow at a auto parts store. And the wheels may need to aligned, the toe and Camber i think it is?
