Airbag light and series of dings - Ford Powerstroke Diesel Forum
Old 05-19-2010, 06:03 PM
Lately the airbag light has been flashing a pattern of 2-7-2-7-2-7-2-7-2-7 then stays on steady as soon as the key is tuned to the RUN position. Also at random times after the truck is running or driving, the dinger will ding 5 series of 5 dings. For some reason, the passenger airbag off light does not work.
I am going to have my buddy run the codes sometime within the next few days so we'll see what comes up.
Old 05-19-2010, 07:06 PM
Mine does same thing. Hopefully someone will have a answer
Old 05-19-2010, 07:10 PM
me too, just started doing it today, hoe someone has an anwser
Old 05-19-2010, 07:49 PM
when your passenger airbag light is burned out, the system senses a loss of continuity, and proceeds to warn you of the failure, with a 5 set series of 5 dings. Enough to make you mental.
I went to the dealer for the part ( dealer only ) and decided that I would rather play pick up sticks with my butt cheeks, than pay what they wanted for the airbag switch.
I took it apart, and found what was required for a bulb. Picked one up at radio shack, carefully soldered it in, and problem solved. just like that. I can't recall the number of the bulb that I got, only that they come in packages of two. For about $3 CDN. so if you are strapped, a couple of you could get together, and float $1.50 each..... anyway.
That is how I fixed the problem.
