E Brake Chime - Ford Powerstroke Diesel Forum
Old 05-19-2010, 05:11 PM
E Brake Chime
I'm new and I tried the search and as is normal for most forums it doesn't work. So new thread. My brake light is on. Brakes are fine. Fluid is fine. E Brake works fine. Light stays on and the chime stays on for one mile. If I stop it starts again. Anyone?
Old 05-19-2010, 11:21 PM
Check the wire to the E-Brake under the dash. Mine was loose on my truck and need to be re-seated. Just look under the dash above the e-brake and push the wire with the white plastic end on it back into place.
