automatic power locks door locks question - Ford Powerstroke Diesel Forum
post #1 of 7 Old 05-19-2010, 07:01 AM Thread Starter
I did some searching on power locks, door locks, etc and did not find what I am looking for. I dunno if this would be better in the interior section or in the Excursion section but here goes....
2002 7.3L Excursion EB. The power locks automatically lock all four doors when you put it in drive. So then you reach your destination put it in park and turn off the truck and open drivers door. Then you try to open the rear doors to get the kids out and !@%^! the doors are still locked.
-Is this normal or should the doors unlock when you put the truck in park, shut it off?
-Is there a way to disable the auto lock feature? I will just set the child locks on the back doors and decide for myself when to lock the doors....
Thanks for the insight...
2002 Excursion 7.3L
stock - Napa 6637 DIY intake
hvywt77 is offline
post #2 of 7 Old 05-19-2010, 04:58 PM
Powerstroke Junkie
NCHornet's Avatar
The dealer can probably turn that off, I am glad my Y2K truck doesn't do this.
NCH
Proud Father of USAF Airman
2000 F350 DRW,CC,LB, 4X4, Western Hauler Pkg.
Ford AIS/ BTM, FTVB
My CCV MOD, Coolant filter
06 Grill, 05 lights,6.0 trans cooler
Cyro/Hawks, JVC Touchscreen HU, JL C5's, Infinity 800watt amp,
DP tunes, 60 tow/80 e/120 race, on a SCT2 tuner
P3 controller, Brite Box Turbo Lifesaver
KMC Wheels x 4
Friends Don't Let Friends Drive Trucks With Generic Tunes
NCHornet is offline
post #3 of 7 Old 05-19-2010, 07:05 PM
my 02 auto locks.
Dietoremain is offline
post #4 of 7 Old 05-19-2010, 08:09 PM
Flooringit's Avatar
Quoted: 27 Post(s)
Just unplug the continous wire. When you take off panel you'll see 2 sets of wire one that plugs into the actuator and one next to it. Just unplug it
Flooringit is online now
post #5 of 7 Old 05-20-2010, 10:29 AM
in your manual it will tell you how to turn the automatic locks off.
turn key on hit unlock 3 times
turn key off hit unlock 3 times
turn key........................etc.
I done mine for the same reason, the kids.
jasonp957 is offline
post #6 of 7 Old 05-20-2010, 10:33 AM
Deactivating/activating the autolock feature
Before following the procedure, make sure that the ignition is OFF and
all vehicle doors are closed.
You must complete steps 1-7 within 30 seconds or the procedure will
have to be repeated. If the procedure needs to be repeated, you must
wait 30 seconds.
1. Turn the ignition key to ON.
2. Press the power door unlock control three times.
3. Turn the ignition key from ON to OFF.
4. Press the power door unlock control three times.
5. Turn the ignition back to ON. The horn will chirp.
6. Press the unlock control, then press the lock control. The horn will
chirp once if autolock was deactivated or twice (one short and one long
chirp) if autolock was activated. Note: Pressing the power door
lock/unlock control again will toggle between activating and deactivating
the autolock feature.
7. Turn the ignition to OFF. The horn will chirp once to confirm the
procedure is complete.
post #7 of 7 Old 05-20-2010, 12:30 PM
goats's Avatar
Quoted: 2 Post(s)
at lease your power locks work lol
goats is offline
