Leaking Wiper Washing Fluid
Is this common? Where does it usually leak from (tried to tell where it was leaking from, but I couldn't)? And if I'll need to remove to get a better look, could I get a description on how to remove it? Thanks in advance. Looking to do this this afternoon, so any detailed help would be much appreciated.
Bump - Anyone?
...easiest way is plug the line off half way..fire up the pump..if theres a hole between pump and hood youll notice fluid squirting out..if not it will build pressure and when cap removed it will come flying out and you know the problems in the hood..
the seals on the pump that go into the tank may be leaking.. |
