More of the same questions. Oil leak from the top of the motor??? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 05-12-2010, 07:40 PM Thread Starter
I've read alot of threads in reference to oil leaking from the valley. I bought this truck in Feb. and knew there was a small leak with one of the braided lines from the HPOP. I have the O rings to fix this seeping leak. Poking around tonight looking at my up pipes I noticed there is oil seeping from around some of the hex heads on top of the drivers side head or by the Y pipe . I cant pin point it without cleaning the area first but what is there that could be leaking. Any suggestions are welcome. Thanks guys, Eric
EArmsF350 is offline
post #2 of 6 Old 05-12-2010, 08:07 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Either HPOP O rings or turbo pedestal o rings more than likely
http://www.powerstroke.org/forum/7-3...diagnosis.html
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 6 Old 05-12-2010, 08:16 PM
Austinj427's Avatar
Best idea is to clean it, and follow it back.
PS. It is a lot of work to get these trucks leak free lol
Austinj427 is offline
post #4 of 6 Old 05-12-2010, 09:10 PM
could be the EBPV piston too, just fixed mine.
Sept. 1st '98 E'99 F250 SD 7.3L International Turbo Diesel 4X4 6Spd Manual, 200K Miles, Supercab 4 door. Pyro gauge, voltage and boost gauge. Current mods include Napa 6637, IDM 140v mod, 4" Exhaust, UVCH quarter mod, HPX, RiffRaff FRx, Coolant filter and IC foil delete.
Visseroth is offline
post #5 of 6 Old 05-12-2010, 09:18 PM
yup mine still leaks... i wanna get a non ebpv pedestal and be done with it.
Dietoremain is offline
post #6 of 6 Old 05-12-2010, 09:40 PM
Old piston and new piston already installed, it's easy to fix but the turbo has to come out.
And here is what it looked like before I cleaned and rebuilt it.
See if yours looks like this.
