Starting Issue - Ford Powerstroke Diesel Forum
Old 05-10-2010, 10:37 PM
Starting Issue
Hey there Fellas, so my truck has diveloped itself a starting issue...
I Noticed it the other day when i was fueling up, the truck didnt want to start so i put my foot on the brake pedal an brought the shifter down to Drive, an put it back into Park, an she fired right up... The truck did it a few times after an also didnt do it a few times... I hadnt driven the truck in a week, so today i went and fired it up an only had to wiggle the Gear shifter... But when i shut her off an tried to restart it, she wouldnt go, i could hear the starter trying to engauge so i held the key in the start possition for about 20 seconds an the motor tried to turn over about four times, but would only get quarter cranks... After fiddling around with the shifter a bunch she finally fired up... I checked the wires to the starter an the transmission shifter linkage, an all clips an harnesess were tight...
I dont think its the starter, but am kind of confused an was wonding if anyone has had a simular issue...
Would it be my shifter linkage?
Any help would be greatly appreciated, sorry for being so long winded...
Thanks in Advance...
-Henry
Old 05-11-2010, 09:51 AM
-Henry
Old 05-11-2010, 11:17 AM
Maybe its a pinched wire in the steering shaft. Fords have a neutral safety switch somewhere and that could be it maybe.
Old 05-11-2010, 11:42 AM
Hopefully its something simple, i was going to take my steering column apart but it was getting dark an ran out of time... What do you mean a Neutral Safety Switch?
Thanks for the reply...
-Henry
Old 05-11-2010, 11:49 AM
Its a switch that only allows you to start the truck in park or neutral. Its under the hood somewhere and if your starter ever goes out you can use a screwdriver to jump across the switch to start the truck. It should be on the passenger side I think on the upper fender under the hood somewhere. It has 4 post on it I think.
Old 05-11-2010, 12:39 PM
Thanks man, i will have a look next time im out at my truck...
I leave it in the country when im in the city, cause she likes to blow a little blue smoke at start up, an the neighbors dont seem to like that for some reason...lol
Thanks again, i will let you know what i find...
-Henry
Old 05-12-2010, 07:49 AM
So i changed out the little Black Gear Selector on the Drivers Side of the Transmission that the 1 of the Main Wiring Harnesess plug into... The Truck seems to be Starting fine again so Hopefuly the Issue is gone... Im heading back out into the Country Later on today so i will know for sure than...
Really Glad i didnt have to take the Steering Column Apart Searching for a Pinched Wire...lol
-Henry
