Leaning? - Ford Powerstroke Diesel Forum
Old 05-10-2010, 08:36 PM
Leaning?
my truck has a new procomp 4 inch lift and the whole drivers side is an inch lower? with all new springs and an empty tank it bugs the Hell outta me makes me so mad and cant figure it out?
- also i get a bad clank right before full lock turning left? its not my tie rod i know that i can feel it in the frame
Old 05-10-2010, 08:43 PM
Is it sway bar bushing? For the clank anyway, can you feel it in your foot when the front tires are unlevel?
Most trucks lean on the driver side... I don't know why?
Old 05-11-2010, 02:16 AM
DJM DJM is offline
if not sway bar bushing check track arm bracket bolts and main bolts or it could be leaf spring popping. as far as the lean don't know it's kinda like on the 05 trucks the driver side tire sticks out farther than the other side atleast all the ones I have looked at. There was a TSB one time about the driver side lean but think it was for the back end.
Old 05-11-2010, 03:07 AM
Feedback Score: 5 reviews
Did you install an adjustable track bar? I can't find one for mine and I'm pretty sure that my track bar is too tight and making the driver's side of my truck sit a little lower than the passenger side
Old 05-11-2010, 04:12 AM
DJM DJM is offline
Fabtech makes one and so does Sky Manufacturing Im not totally sure but for it to fit an early 99 I think you just have to drill out the hole size in the bracket I think thats the only differance besides the diameter of the actual rod. Im sure if you gave one of them a call they could help ya. Im sure it's possible with all the early 99's runnin around lifted.
Old 05-11-2010, 07:30 AM
Eric I have thought the same thing about the track bar I have a brand new on3 at the house I have thought about taking mine off and seeing how it sits but my adjustable is for a 6 inch lift but I'm gonnacheck my bushings on my sway bar. When mine clanks my whole bumper shakes and everything.
Hey Eric what did you do with your old wheels?
Old 05-11-2010, 08:39 AM
Which ones?
Old 05-11-2010, 10:14 PM
Originally Posted by Eric View Post
Which ones?
Your bmfs and your tires
Old 05-12-2010, 03:02 AM
The wheels started pitting and the caps wouldn't fit them so I sent them back. I sold the tires to a member on here
