What's the biggest Tire you Can Run????
I found me some 17x9 rims im looking to get this week so i'm wondering whats the biggest size tire i can run before I would need to add a lift or the biggest I can go without the tires rubbing???? Any help will be appreciated and pics of your setup as well Thanks
35s with add a leaf. Rubbing also depends on wheel backspacing and tire width.
Cool.... I was thinking of going with only 30's or 33's.. How much the leaf spring usually run?
The add a leaf is usually around $100 it's just a thicker leaf with more of an arch to it you gota split the spring pack and put it in the middle. Or you can get an actual levelking kit wich is new front springs usually cost around $500 or so. Personally I would go with the 33's I think it looks better. Is your truck a 250 or 350 should of asked you that the 350's sit a tad bit higher. Or you could go with drop shackles in the front good thing about drop shackles is it keeps the factory ride feel. Check out this website if you wana go with a shackle lift prety good price.
http://www.sky-manufacturing.com/new...d5aa2606ce9ea2 Last edited by DJM; 05-11-2010 at 07:58 AM. |
I got a 2002 F250 and yea im leaning towards the 33's! And the wheels im getting are 17X9..
Here are the specs to get more or better replies. The rims are pro comp 6005 series 17x9 with 4.75 backspacing! Looking to see if I can run 30's or 33's without rubbing
bump for the am
My dad has 33x10.5 Toyos on his truck stock and it's a 250 no rubbing. Stock tire height is about a 32-33
Thanks... Yea I called a couple tire shops and they said the same thing..
Hey what about these??? 17 18 and 20" 8 lug wheel blow out Ford Hummer H2 Chevy : eBay Motors (item 400121270391 end time May-17-10 09:41:13 PDT) Great price IMO for 18's brand new |
I would go with either 17 or 18's save you a little extra in tire cost plus if you do any offroad stuff like hunting and such with a 33 and 20" rim there is a good chance of dingin up the wheels cause their aint much rubber there. I know you said you were probably gona go with 17's anyways thats what I ended up goin with was a 17 there are more wheel options it seems with 18's though. NIce lookin rims damn good price too.
