New Truck w/Pics & Questions - Ford Powerstroke Diesel Forum
post #1 of 8 Old 05-10-2010, 11:04 AM Thread Starter
SHANE M's Avatar
Hello all. I finally sold my Cummins and went back to the Powerstroke.
This is a 99. I dont know if it is early or not because the rocker sticker cannot be read any more.
My questions are:
The electrick door locks do not work. Sometimes one of the will work but it is very weak. When I push the door lock button you can hear the actuator but they will not lock/or unlock. Do I need to replace the actuators or could there be some thing else?
The switch assembly for the power seat on functions sometimes. Does anyone know where I can get a new switch assembly besides the Ford dealership?
Any help is appreciated.
-Shane
SHANE M is offline
post #2 of 8 Old 05-10-2010, 11:08 AM Thread Starter
SHANE M's Avatar
Mean to post this one. Not that one twice
SHANE M is offline
post #3 of 8 Old 05-10-2010, 11:12 AM
RaZe's Avatar
nice, huge potential
get like this
Originally Posted by ExtremeFord4x4 View Post
I miss my old black truck. It was an 01 converted to an 07 hd front and 08 rear. And the best part it still had a 7.3!
2001 F250 Lariat Xcab 4x4 Short Bed
-Zoodad mod
-AFE stage II
-Smoked 2008 Taillights
-Recon Smoked Brake Light
-Full 2007 Conversion w/ Harley Lights
-MBRP 4" str8 pipe w/ RBP 6" tip
-Tailgate Brake Light
-Autometer:Boost, EGT, Trans Temp
-PHP/TW "Twin Tuned" Chip
-DDM 6k HiD's
[Stock,Lope,TWecon,TW140,PHP140,PHPSMOKE]
SOON TO COME
-20x12.5 black wheels
-6" lift
-recon smoked cab lights
-35x14.5 Mudders
Support Our Troops
ODA-5122
RaZe is offline
post #4 of 8 Old 05-10-2010, 11:24 AM Thread Starter
SHANE M's Avatar
That's a sweet ride!
My wife would have a hard time with the car seat though.
She complained when she had to climb in this:
SHANE M is offline
post #5 of 8 Old 05-10-2010, 12:24 PM
Take your door panels off and try to lube the door locks. They sometimes get sticky with dirt on mine and I have to lube them then all works good until the next cleaning.
EArmsF350 is offline
post #6 of 8 Old 05-10-2010, 06:21 PM
IBEW Journeyman Lineman
PolarBear's Avatar
There is a foil mod for making the power door locks work again if you are that much off a DIY person or you can change out the door lock actuators whichtend to get weak. I just put new front and rear passenger side actuators in my crew cab and because mine were weak and would barely move. Not enough to lock or unlock. Best deal I could find on them was from powerstrokeshop.com.
2012 F350 XLT CCLB 4x4 6.7
PolarBear is offline
post #7 of 8 Old 05-10-2010, 06:28 PM
F250 Fever's Avatar
Send a message via Yahoo to F250 Fever
theres a write up on here that someone did on fixing there door locks them self
2000 7.3 F250 FX4 ext cab short box
Cobalt Pillar Trip pod gauges, trans temp, boost, pyro
4in down pipe to a 5in tip
KnN intake
Tuned by PHP
Banks big head waste gate
6in Pro comp lift
Mag hytec tranny pan
Diablo predator programmer (used for pulling codes)
Foil delete
ATS Turbo housing
Halo projector headlights
BUILT TRANNIE-
Euro taillights
Radar detector
Window tinted 20%
F250 Fever is offline
post #8 of 8 Old 05-10-2010, 06:43 PM
Austinj427's Avatar
Yeah, someone needs to find that write up. I did my passenger side one. It took about an hour to get the damn thing out, 10 min to do the mod, and 45 min to put back in.
It locks like fort knox now.
If you are handy I would do it. It cost you some time and aluminum foil. Basically, there is a metal connection plate inside the window actuator. The actuator itself is "non-servicable" but anyone with a drill and a few bits can drill out the rivots.
You take the motor out, open it up, put aluminum foil around the little metal bar thingy and put it back together with little self tappers.
As for the power seats, a little lube usually helps that out.
Congrats on the new truck. It looks great.
Austinj427 is offline
