Long crank time suggestions?
My 03 7.3 has a longer than normal crank time, The batteries are fine i tested them with a battery tester they were good, the engine turns over strong, the truck runs fine when started but its not the glow plug beacuse i can run the truck for a long time then shut it off and then fire it up 3 seconds later and it still has a long crank time. Can it be the CPS that ford had a recall on? Any other ideas would be great
these trucks kill starters. replacee it i bet you'll have no prob cranking her up.
I dont doubt that they do but it seems like the truck is not holding its fuel prime it seems like the starter is cranking strong but it makes a different sound than our other 7.3, the other truck cranks over smooth and starts quicker this one starts but its got a napa rebuild and sounds like crap.
I assume youve changed the fuel filter recently? have you checked your fuel pressure?
dont get a napa starter, here is what we reccomend, i just put on it and just bump the key to start. NEW Ford 7.3L Diesel Starter POWERSTROKE Truck 01 02 03 SND0355 17802: SND0355 --- DB Electrical Starter-Alternator |
yes I have changed my fuel filter, its a baldwin. And no I have not checked my fuel pressure, its like the fuel pressure is bleeding off once the truck is shut off. And the starter is a napa that came with the truck when i bought it. But it doesnt sound like a stock ford starter, it sounds ruff but the engine seems to be turning over strong but you never know
maybe injector problem....
just posted a starter thread yesterday ill find it for you... DEf your starter.
Replaced Starter Heres w=What It Fixed..... there you go i couldent belive the difference. |
crankshaft position sensor. ok, had that replaced recently due to recall. hand prime truck and it'll run. just can't get it to self prime right now. grrr....
