Balancing the drive shaft??
since i have had this vibration problem getting progressively worse over the last i have been trying to find what it is..
my latest diagnosis is the drive shaft being unbalanced, i figure its a good possibility because i had the transmission out and the vibe started as soon as it was back in... so my question is how is the best way to go about balancing the shaft? |
are you sure its not your U-Joints cause i was having the samething when i would drive slow like around 25 30 mph the whole truck would just vibrate....and it was my u-joint
that is def a possibility but i replaced all three u-joints and the carrier bearing less than two years ago...
well granted you replaced them but...they maybe worn out...a good way for that to tell is crawl underneath the truck with it off and everything and if u can turn move the driftshaft coming out of the trany at all then the u-joint needs to be replaced...
alright ill go check them out, anything on balancing the drive shaft though?
find a local drive shaft shop. I ha mine balanced for 65 bucks.
The trans mount can also have gotten real worn. The slip yokes can cause the vibrations too. |
you know to be completely honest i have not heard of doing that before....
i checked the drive shaft, no play what so ever... any other ideas for the vibration?
torque converter, front end components, etc... i have been trying to figure this out for over a year and i keep hitting dead ends and its getting worse, can anyone help me? |
water in the tires. mud in rims, drive shafts bent, carrier bearings rubbers gone, bent rim. warped rotor...
whats the actual vibration speed 0-100. 50-65? can you give us a general area its coming from..front left.... center. torqe converter wont make vibrations a flywheel out of balance would show but you would notice a oil leak before you noticed vibration. need some more info |
