glowshift gauge questions... - Ford Powerstroke Diesel Forum
post #1 of 3 Old 05-09-2010, 11:31 AM Thread Starter
rt_hawk's Avatar
Hi guys, for those of you who have the glowshift 3 in 1 gauge...
-where did you hook up your boost sending unit? The instructions say you may have to drill and tap your intake manifold and I would like to avoid that...
-what size drill bit do you use to drill the hole for the pyro gauge? And what size tap? 1/8th inch NPT right?
-And does the trans temp sending unit just go in the test port, or that second bold from the left?
Thanks in advance,
rt_hawk
rt_hawk is offline
post #2 of 3 Old 05-09-2010, 04:17 PM
Mikey's250's Avatar
I dont have the 3 in 1 but I have 3 seperate glowshifts. For boost you can put a T in the MAP sensor line. On the pyro I just pick the bit that was a little smaller than the threads and went from there. And for the trans I cant remember where I put it and Im not near the truck to look. Somebody else will give a few more details Im sure
Mikey's250 is offline
post #3 of 3 Old 05-10-2010, 05:57 AM
dannanw's Avatar
Quoted: 67 Post(s)
Garage
I have one and tapped the map line, the trans unit goes in the same hole the rest to, i found picts on here (thats the reason I joined). and I dont have it in front of me but I think it is a 11/16th? look at your tap (if it is new) and it will tell you the size bit on the box. have picts somewhere lol
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
