Newer headlights - Ford Powerstroke Diesel Forum
Old 05-06-2010, 07:10 AM
Newer headlights
what would be needed to run 05 headlights in my 00 other than the lights themselves? looking to pick up a set and wondering if i will need anything else.
thanks guys
Old 05-06-2010, 07:51 AM
Updated plugs at the headlights. Either get them from the dealer (waaay $$,where I got mine from) or get the DFuser conversion kit. And you're either going to need to do lots of cutting on your header panel, or swap in a new one from a 2005-2007 truck.
Old 05-06-2010, 12:11 PM
I got my lights off Ebay, after market, but so far so good... ran about $210 with shipping. Got the GOS Racing relay harness, that was $70 with shipping.
Install took about 2 hours, a side grinder and a wiz wheel/cut off disk, a sawzall with fine tooth blade, minor hand tools. For sure, take the header panel out and cut it... it's easy to do. I had a picture printed off and in front of me when I did, some one posted it around here somewhere with a pic/drawing of where to cut. With that in front of ya, and the new lights in hand, you'll see where needs trimed to work right. The new wiring harnes was plug-and-play easy, however, I did have one of the relays go bad a week or so ago, but was replaced at the local parts store for about $10.
Way better lights... get them adjusted, and wow!
Old 05-06-2010, 12:14 PM
you will have to cut up your header panel.. check out this link: 05-07 CONVERSION instructions. ( here )
and you will need something like this: Stealth Automotive Inc - Lighting :: headlight Blulbs :: 9007 to H13 converstion harness
or if you want to run HID's we can make our HID's work with the old OEM wires into the new headlights..
let me know if you have any questions
-Raul
Old 05-06-2010, 12:48 PM
Header panel if you don't want to cut yours up.
Old 05-06-2010, 07:10 PM
No need for relays unless you are running higher wattage bulbs.
9007 to 9008 Headlight Conversion Harness BEST QUALITY : eBay Motors (item 230412981904 end time May-14-10 17:19:50 PDT)
I got these, cheap and work great.
Old 05-07-2010, 06:55 AM
whats involved with taking the header panel off? bumper, grill intercooler...?
Old 05-08-2010, 02:35 PM
thanks guys that helps a lot. still waiting to hear back from the guy that is supposed to be selling me his lights. probably just gonna cut up my stock header panel. and get the harness
Old 05-08-2010, 05:48 PM
The header panel comes out easily... remove the grill, it's just a few screws along the top and a snap clip at the bottom, and the header panel is just behind it... the headlights can come out attached to it, I found it easier to remove the whole mess than try to take the headlights out first. You'll see what I mean when you get to it...
I made it hard on myself, I had the grill guard in the way like you see in my sig pic... I was able to remove and install the headder panel with the grill guard in place.
Old 05-09-2010, 06:31 AM
thanks, i didnt know if i had to detach/remove the radiator and intercooler and such.
