Upcoming trip, what needs to be done... - Ford Powerstroke Diesel Forum
Old 05-05-2010, 08:52 PM
Got a long trip planned in Aug in my truck, probably 2300 miles or so. No real issues at the moment, other than a flaky fuel guage that sometimes works, sometime sticks at full, burns a little oil, 1 qt every 2000 or so (doesn't seem to use as much on long road trips for some reason) and a little smoke at start up when the engine is cold.
I changed the tranny fluid a few 1000 miles ago
Will change oil before the trip
I have 177k on my truck, probably 183K by the time the trip rolls around. What do all you pros think I should do or have checked before hand?
Thought I'd plan well ahead in case there's anything big I need to get on.
Thanks.
Old 05-05-2010, 09:05 PM
I'm not pro but I would just make sure you have extra oil.
177k, how long since the bearings were replaced? They are a closed bearing if it's 4x4 I think.
Had mine go out from CollegeStation to Dallas (3hr drive). And all I had to do to prevent that was re-pack them.. Oh well
Old 05-06-2010, 07:48 AM
Change the oil and go. I took mine to California and back two years ago (4000 miles round trip). I asked what I should do... the responses varied, but basically I should have brought a spare truck along to keep them all happy. I brought an extra serpentine belt, a spare CPS, and an extra jug of oil.
Old 05-06-2010, 09:52 AM
This, and maybe a couple jugs of water.
Old 05-06-2010, 07:19 PM
...basically I should have brought a spare truck along to keep them all happy.
Too true. I got similar responses last time I posted like this.
I'm more concerned about the mileage on the truck and if there was anything I should really check due to the 183K or so that will be on it by then. Hopefully if something's going to need fixed it will break before that.
Yup, I always pack a gallon of oil and 1 of coolant too on long trips. Spare CPS, belt and fuel filters, plus tools and my scanner. Wish I would have had that last year on the same trip when the ABS speed sensor went out.
I'll have to look into the bearings, I don't know about if they're sealed or not on mine.
Thanks!
Old 05-07-2010, 04:48 AM
I can tell you right now that they're sealed, unless you or the previous owner decided to drop the $2000 on the Dynatrac kit.
Don't worry about it though, it is entirely possible to change the wheel bearing using a standard Craftsmen tool set and the factory jack... even though it's a bit shakey.
