What are the signs of a bad starter?
I am trying to figure out was is causing this b.a. sounding lope when i first start the truck. If i let the truck sit for a day or two then start it is has a hard lope to it. One day after sitting for 3 days it loped 3 times and died, then started again and loped 2 times then died, then i started it again and gave it gas loped right at the start but sounded great and run normal after that. What does this sound like to you guys? Here's the problems. I just had a bad fuel line. It had a hair line crack in it. It is the 1st/front fuel line off the fuel bowl on the passenger side that runs to the back of the head. Got a replacement line for around $50 bucks and now no longer leaks. This was after i got the fuel bowl valve drain replacement which wasn't the problem but nice to have a new one anyways. Still have the lope thing happen. My next step will be to use sea foam and put a new fuel filter in. Wonder if this has something to do with starter which sometimes doesn't always start the fastest. Also there is no smoke when any of this happens not black or white. Guess that is a good sign. Let me know what you guys think also run great after it runs. |
Ohm out the injector harnesses. Mine needed the uvch clip on the pass side. The uvch get burned out. Also check to see the oil level in the hpop reservoir in the morning before you do anything. It needs to be close to full. About an inch down.
After that my guess is the uvch |
Does this mean i might be in the market for a modded HPOP?
possible, try looking into the reservoir in the am. Then post back
Will do thanks
bump this up
Actually sounds more like a bad ICP sensor
Someone else has told me this also. Stroke_This_F-250 is my brother and he has my truck at home right now. When he gets up im going to see if he can check out the hpop and this other stuff.
Thanks |
if the sensor is bad, unplug it, see if its got oil all over and in it. The sensors leak out of the top.
Unplug it and start it. It should set to a default setting and start it fine. |
