Fuse Box/ Owners Manual
I was checking my fuse box to see if my fuse was blown because my overdrive isnt working... Well I checked my fuse and there are a couple blown ones but I dont have a owners manual to see what fuses are blown... Anyone here have a manual or a link to see the diagram for a 2002 F250 7.3 liter fuse box?????? Someone please help me
Ok, I found the diagram but its says nothing about a overdrive fuse. Am I missing something?? Is there a fuse for the overdrive switch???? The problem im having is when I press the switch it doesnt turn on just trying to diagnose it
Well, of course, every item doesn't have a separate fuse or is even identified as to which fuse it's associated with.... so check 'em all
![]() But, my first thoughts would would be to check under the steering column cover because it's not uncommon for the wires to chafe there as they go to that stalk. |
Under the driver side dash in position 5 is a 15 A blue fuse that protects both the turn signals and the overdrive switch. I have had this fuse go out due to the overdrive off switch. I plan to check the wiring in the steering column. Does anyone know if this switch operates a relay and if so where is it ? A circuit diagram for the Overdrive would sure help.
rpogrady@yahoo.com |
