need new pcm - Ford Powerstroke Diesel Forum
Old 05-03-2010, 11:58 AM
need new pcm
getting false boost readings from pcm .All sensor's test fine on the input side to the pcm but it doubles the boost reading coming out . this was confirmed by scanning pcm and a manual gauge tee in to the map sensor line. Best place to get new pcm.Would perfer to get diffrent pcm and not have this one flashed
Old 01-26-2012, 12:25 PM
Wonder if getting a new pcm fixed the problem? I am having the same issue on my 01. gauge says 15 psi and the edge says 26 psi. Any Ideas?
Old 01-26-2012, 04:01 PM
I have had no issues with the truck since the new pcm was installed.
Old 01-26-2012, 06:17 PM
How much different did it run when you put the new pcm on it? Where did you get yours from?
What year is your truck btw?
Old 01-27-2012, 06:51 PM
It is a 2002 and got the pcm from Ford. It runs like a stock truck should .
Old 01-27-2012, 06:53 PM
what boost level are you seeing?
