Coolan Filtration - Ford Powerstroke Diesel Forum
Old 05-02-2010, 04:24 PM
Send a message via MSN to dusted4eva
Coolan Filtration
Just ordered the coolant filtration kit http://www.dieselsite.com/index.asp?...WPROD&ProdID=8 I lost my water pump last weekend so I did a coolant flush. Tried this 7.3L Power Stroke Coolant Changing Instructions - Engine Care & Maintenance Forum method the best I could. There was over a cup of sediment circulating in the system. I should have taken some pics. I hoping this system will help clean the rest out.
Old 05-05-2010, 04:13 PM
I want to get the same filter system, how did your water pump fail, bearing or leak?
Old 05-05-2010, 05:13 PM
It was leaking aprox. one gallon an hour when it failed.
