Cannot remove fuel filter lid-damn - Ford Powerstroke Diesel Forum
Old 04-30-2010, 02:59 PM
The former owner of my 2001 F250 yarded down the plastic top on the fuel filter so much that I can't budge it. All I'm doing is skinning off the edges the plastic built in nut.
Is there a trick to this?
Old 04-30-2010, 03:17 PM
Got any pics of your lid????
Mine has 'spokes' on top and I have tapped on those to get it tighter or loose to take it off.
Old 05-01-2010, 05:53 AM
Powerstroke Junkie
If your's have the rubber coating on the nuts strip it off so a wrench will fit on it. Otherwise vice grips are your friend!!
Old 05-01-2010, 05:56 AM
duct tape & zip ties
Chisel and hammer. That will get your cap off. Most new fuel filters like the Fram I use comes with a new cap.
Old 05-01-2010, 03:22 PM
If it's got the fins take a pair of pliers with the handles in the fins and use a screwdriver to turn the pliers therefore turning the lid.
Old 05-01-2010, 03:49 PM
it took me forever one day to get mine off but ended up turning pliers upside down and using the handels and a screw driver like mentioned above
Old 05-01-2010, 05:33 PM
DJM DJM is offline
Yup what they said.
Old 05-01-2010, 05:43 PM
KING of BLING!
Or a flat head and a hammer. I forget which ones come with a new plastic cover? I want to say napa. So do and some don't.
Old 05-01-2010, 08:10 PM
Napa ones come with a new plastic cover that you can get off with a socket.
Old 05-01-2010, 10:36 PM
Yeah sounds like a WIX filter. Chisel and hammer, that sucker is on there so tight so it doesn't leak (I'm not a fan of their 'improved gasket') that's the only way to get it off. Get a factory cap and filter and enjoy!
Scott
