Edge EZ vs. Juice
Is there a difference between them, the EZ is supposed to be stackable, I don't know anyone that has the Juice installed tho.
IIRC, both are designed to be stackable. EZ just connects to the ICP sensor, the Juice connects to the throttle position sensor, ICP sensor, and MAT connector. I don't have either, but I think the Juice is just a nicer EZ with the option of being able to add the Attitude monitor, and defuel the engine when EGT's get too high.
With a chip does does the power rating add up or do they do similar things. If both power settings are at 60, does that make it 120, or do they do similar tuning so the hp would only be 70-90? Thanks for the info
Your close, they do some of the same things. I have the juice and the EVO stacked. I can certainly tell a gain when I stacked the EVO. The EVO is much better as far as tranny adjustments, but it ends there the Juice is completely adjusts everything else... |
