5yr/100,000 mile warranty - Ford Powerstroke Diesel Forum
Old 04-05-2006, 06:57 PM
Send a message via AIM to 01SMOKINSD Send a message via Yahoo to 01SMOKINSD
Ok guys, need to pick your brain. I have an 01 PSD and im taking it in monday to have the rear main seal in the engine replaced, and the front pump seal in the trans replaced. I only have about 3 more months left under the warrenty and want to get everything fixed before it runs out. What Im wondering is if this warrenty covers the rear end and front axle also. The warranty is listed as a powertrain or driveline warranty, and i consider the axles to be part of the driveline. Im having a vibration in the rear when i take off from a dead stop. Not sure what it is but would like to have it looked at while its there if its under the warranty. Any help is appreciated. Thanks!!
Old 04-05-2006, 07:01 PM
i work for a dealer.......the warranty ONLY covers the motor and most parts bolted to it.......so the driveline stuff isnt covered.....
that vibration from take off is "normal"....it is the driveline angle......it can be kinda fixed..but it will always do it in one condition.......if it does it loaded now...it probably doesnt do it unloaded......you can only fix it to not do it one way........PM me and ill give you my phone number if you want a better explanation....Marc
Old 04-06-2006, 06:57 AM
Ok, thanks. I wasnt too concerened about the vibration cause its only there for a split second. Im a mechanic myself and usually do my own maintence and repair, but i figured if it was covered under the warranty id let them mess with it. One other question I have is do you know perchance that if the rearmain seal is leaking and they have to pull the crank. Does Ford or International also pay for the bottom end to have new bearings put in? This is assuming the seal is a one piece seal and the crank does have to be pulled. Thanks.
Old 04-06-2006, 03:20 PM
the rear main is one piece and just the tranny needs to come out.....but look very closely on top of your motor in the valley.......ive only EVER seen one 7.3 with a true rear main leak....it is one of the most mis diagnosed leaks in the car industry.....Marc
Old 04-06-2006, 08:28 PM
There's another way to fix the vibration. If you can stand it then dont worry about it but if you want it gone do away with the two piece driveshaft and get a single unit made from the trans to the diff.
Old 04-09-2006, 12:24 PM
Marc, Im guessing that your saying to check the O-rings on the turbo pedistal? I didnt look too closely just happened to notice it leaking when I did the last service. Is there anything else that I should check for possible leaks to have fixed while its in the shop? Thanks!
Old 04-09-2006, 01:02 PM
there are o rings between the pedestal and the turbo, the pedestal and the block....there are three o rings on the high pressure oil pump that are a relatively common leak, quite frequently the four hose clamps on the orage tubes between the charge air malifold and the heads loosen up and leak a little oil........there are a lot of things up top to leak oil....and that is FAR more common than a rear main.....like i said, its virtually never the rear main........Marc
Old 04-09-2006, 04:29 PM
Ok, Thanks Marc. I did notice some oil residue on the orange air tubes up top. I just noticed oil drooling down the back side of the oil pan, and from what I could see it looked like a rear main, but its good to know that, that is probally not the culprit.
Old 04-09-2006, 04:32 PM
you would be amazed at how that little bit of oil coming out of those orange tubes can collect on the seam between the head and the block....and also at the back of then engine valley over time and pool up and eventually look like a huge leak....and if the clamps are loosened up over time from running...the amount can be even more........Marc
Old 04-09-2006, 04:34 PM
by the way....your 5/100k warranty will cover any oil leak period......minus the 100 dollar deductable of course....take it in now so you have documentation of the leak so if they dont fix it you can have proof that it was leaking before the warranty ran out......Marc
