Power Question
hi
I have a 2000 powerstroke 7.3 with a 6 speed,(4 speed with low and OD) 4x4 stock and was wondering how much the injectors will alow for horse power wise. I know the oBS will get like 275 or so tops with stock injectors but i dont know about the newer motor. I wanna put a intake exhaust and tony wildman in it with gauges. Also the downpipe looks pretty big, is it nesecery to swap in a bigger one? So with these mods what will i be lookin at for HP, TQ, and drag times and speed approx. Thanks
your DP should be fine. iirc the stock injectors are 120cc. rice numbers put you at + 140hp, but i dotn know if thats at the crank or wheels. so you flow 30 to 40 more cc's max. i doubt youll actaully see +140 at the wheels.
Injectors are just part of the puzzle, larger sticks needs Adrenaline or Big Oil, a better fuel delivery system and more fuel means more air so a larger turbo is also on order. That is why mine is staying where it's at, plentu of power for me. The next jump ends up being 10 grand plus!!!
larger inj's..stage 1's or 2's single shots do not need any larger HPOP than a stock 17* pump and can get you 450HP+ with support mods
A 2000SD should get to 330HP with stock Inj's but HPOP won't like it. Singles should get you to 350+ and 2-3 MPG's with a 17* pump Your trans and turbo won't like larger than stage 1's either Cary |
