Switched electrical power - Ford Powerstroke Diesel Forum
Old 04-25-2010, 10:40 AM
I am trying to wire up my 08 center console i am putting in my 03 f350. I want the outlets to be on switched power and not on all the time. Anyone know where i can find a wire to tap?
Old 04-25-2010, 10:56 AM
There should be some wires taped up by your master cylinder that say "Customer Access". You might need to add a fuse to get them to work. Or, you can bring the truck by my place and we can start poking around with my multi-meter. Seen it out a few times now... looks good with the graphics.
Old 04-25-2010, 04:31 PM
Are these the wires you are talking about? I couldnt find anything that says customer access. Although i did find a fuse a while back for customer access. It already has the fuse in it.
I do have some zip tied to the master cylinder but they plug into it.
Old 04-25-2010, 06:09 PM
Anybody else?
Old 04-25-2010, 06:34 PM
I would start poking around with a meter.
Old 04-25-2010, 07:22 PM
Well none of those 4 wires worked. hmmm
Old 04-25-2010, 07:24 PM
Those would be the 4 wires. Might want to double check you have the fuse in or that it isn't blown.
Old 04-25-2010, 07:32 PM
I checked the fuse. It says its a 10amp and it is in there and not blown.
I started up the truck and used a wire with a light on it to try and figure out which one. None of them light it up.
Old 04-25-2010, 08:18 PM
Weird. Do you want it to always have power or just when the key is on?
Old 04-25-2010, 08:21 PM
When the key is on. I want to leave things plugged in without training the battery.
