Cruise Control Problems - Ford Powerstroke Diesel Forum
Old 05-01-2007, 04:22 PM
My cruise quit working, I checked the fuses and they are fine. Everything else works fine. Anybody have any ideas.
Old 05-01-2007, 04:24 PM
duct tape & zip ties
How about the switches or wiring in the steering column. Bring it over and lets take a looky ok.
By the way welcome to the site.
Old 05-01-2007, 06:16 PM
Strokin' In Dixie-Land
to THE site!!!!
Old 05-01-2007, 06:34 PM
Ive had to replace the sensor on the master cylinder on mine to get the cruise working right.
Old 05-01-2007, 06:39 PM
does the horn work?.?.its on the same circuit
Old 05-01-2007, 07:27 PM
If the horn isnt working either then it is your clock spring. If the horn is workin youve got other problems
Old 05-01-2007, 07:48 PM
HardLuck Case of the Year
Send a message via AIM to Ditty Send a message via Yahoo to Ditty
I've had a little problem with mine since I bought it. I have to push the button ON button pretty hard at the VERY top of the button...after that all is well. Just something for you to check.
Old 05-03-2007, 01:55 PM
Horn works fine, I've got a bad feeling there are some chaffed wires. The guy that owned this truck before me was a little rough on her off the highway.Great site,I did the intake mod that Maintain posted seemed to help. I will pull the switch off and test it. Thanks guys, I"ll keep you posted.
Old 05-03-2007, 03:34 PM
use you foot to pull the emergency brake pedal all the way up... that was the problem with mine! the parking brake sensor wont allow you to use cruise if it reads that the brake is engaged even a little bit!
Old 05-04-2007, 12:15 PM
My CC works when it wants to!!! I dont know why . I have tryed what poeple have posted. But with no luck . If I am under about 40mph It works good, above that it turns off all the time.
2003 F350 6speed 6.0L
