manual to auto conversion? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 04-22-2010, 10:23 PM Thread Starter
First off, i did search the forum prior to post.
ok, most people appear to Want a manual....
however i bought a 99 f-250 today with a 6spd manual, the tranny doesn't shift in to gear, and i have never had a diesel (had a '95 and a '92 ford diesels, 5spd's) that i enjoyed shifting....they've always shifted poorly in my opinion, oh and i'm lazy.
So, seeing as how my tranny needs some love, i'm thinking i might swap to an automatic. i'm figuring i need:
auto trans, torque converter, flywheel, auto pcm, auto brake pedal (optional), and an auto steering column. aside from those things, am i missing anything, seems like it would be a fairly straightforward swap...primarily seeing if i missed anything and hoping someone else out there has done the swap that can give me some tips.
azpsd is offline
post #2 of 10 Old 04-22-2010, 11:18 PM
Rangers Lead The Way!
kanuck15's Avatar
Quoted: 10 Post(s)
driveshafts. the auto wiring harness. i do believe the auto t-case is different. and if you have done anything to your truck like a chip its gotta be reflashed as well
Trucks and parts............
kanuck15 is offline
post #3 of 10 Old 04-22-2010, 11:25 PM
sawyer1's Avatar
Man i would love to swap u where you located..prolly far away my luck....
-Sawyer-
USAF COP!!
2000 F-250 Lariat, 142,000mi automatic trans.
SOLD SOLD
New rig 2006 dodge cummins mega cab
sawyer1 is offline
post #4 of 10 Old 04-23-2010, 09:06 AM Thread Starter
mines a 2wd so t-case wouldn't be a concern. i'm in phoenix sawyer1. i'm going to see if i can find a smashed, rolled over, pile of crap to use for the swap....
azpsd is offline
post #5 of 10 Old 04-23-2010, 03:41 PM
kodeman's Avatar
I just bought pretty much all the big items ill need to swap a 6 speed into my 99 f350 . I have a somewhat built auto with about 12K miles on it, i am going to sell with all the stuff that goes with the manual to auto swap. Sucks that you are 2wd cause i have EVERYTHING you would need. and you have stuff i need. ha .
Im located in Sacramento,ca
7.3 PSD, Swap'd in ZF6 ,South bend clutch ,BD exhaust brake, 4" lift & 35" Toyo AT2 , 6" Exhaust ,PHP Phoenix, .
kodeman is offline
post #6 of 10 Old 04-23-2010, 07:37 PM Thread Starter
a mechanic friend offered to pull the 6spd out, and fix it for $100 plus parts....so i guess for now it'll remain a 6spd (i'd be stupid to turn down that deal)
azpsd is offline
post #7 of 10 Old 04-23-2010, 07:42 PM
KeepinItFord's Avatar
DriveShafts? since when? and i dont think the tcase is different at all.
KeepinItFord is offline
post #8 of 10 Old 04-23-2010, 07:46 PM Thread Starter
i though the driveshaft would be the same, but perhaps the splines are different? i've never compared them. mine has no t-case as previously stated so thats a moot point in my case.
azpsd is offline
post #9 of 10 Old 04-24-2010, 08:07 PM Thread Starter
transmission is out, just waiting for word on what is wrong with it.
azpsd is offline
post #10 of 10 Old 05-19-2010, 06:22 PM Thread Starter
ended up 2 roll pins fell out of the shift forks. though now it doesn't want to shift due to the slave cylinder i think.
azpsd is offline
