removing an exhaust manifold. - Ford Powerstroke Diesel Forum
Old 04-22-2010, 04:58 PM
Whats the chances if i remove one exhauct manifold to replace the gaskets,the bolts will come out and not all snap off?
How often do you guys need to or hear of people replacing the gaskets between the manifold and the head?
thx
Old 04-22-2010, 05:06 PM
DJM DJM is offline
I thought I read somwhere there was no Gasket probably wrong though, but my guess would be to use lots of penetrating lube if you can get a hold of some Kroil that stuff works awsome usually only industrial places can get it though I snagged a case of it from work though just to have best stuff I have used.
Old 04-22-2010, 05:09 PM
Heat the studs up with a torch. Just be careful not to mess up the heads.
Old 04-22-2010, 05:24 PM
does anyone know if there is gaskets in there? Hate to do it, to find out there are not any?
