Dash speedo and gauges!
Hey guys, I'm jumpin' head first into the diesel world. Just bought a 2000 250, 6 speed extended cab short box with 148,000 miles and I'm the SECOND owner! I drove it 360 miles back and got a hand calculated 18.9 mpg's!
The truck has a few minor issues I'm trying to figure out, one of them is the speedometer. Its broke but the rest of the gauges still work, the dealership i bought it from is sending me a new gauge cluster to put in. I'm wondering if anyone has replaced theirs before and if so does anyone have any tips or 'How To's?' On a side note, right now its factory but i ordered all new fluids from AmsOil. 4 inch mbrp exhaust and an AmsOil filter for a DIY intake system. Puttin everything in this weekend. Thanks for the help |
Sounds sweet.
I have no idea about the gauge cluster. I'm sure once everything is apart you can figure it out. Have fun! |
have you or anyone had your dash apart? does everything just unsnap and pull off?
Usually when the speedo fails it is the rear VSS. It sits on top of the rear diff. IIRC a 10mm bolt holds it in place. They are cheap, I would try swapping a new VSS in before tearing the dash apart. Haven't heard of to many gauge clusters going bad. So I assume the odometer doesn't woirk either, so how do you know how many miles the truck has on it? Good luck
