new transmission mount, poly? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-20-2010, 07:10 AM Thread Starter
I am looking to get a new transmission mount for my 01. Does anyone make a poly bushing? Or something a bit more solid then a stock one? If so, can it be used with the stock motor mounts? I think, I finally got rid of most of my 45 mph low rpm vibrations. I installed 3 brute force u joints from advance auto.
Turns out they were poorly made and loose fitting right off the get go. Just got my driveshaft back from the local driveshaft place with their u joints. Much much better. I still feel the vibe at the same rpm but a 1000 times less. I hit bumps in the road i feel like somethings loose right under my seat. I may try to do a different trans mount. Any suggestions on what one or where to get it.
ps: all crossmember etc bolts are tight.
thx
2008 6.4 f250 lariat 4wd
melmount is offline
post #2 of 4 Old 04-20-2010, 09:32 AM Thread Starter
bump..........
melmount is offline
post #3 of 4 Old 04-21-2010, 06:06 AM
Powerstroke Junkie
NCHornet's Avatar
Call Energy Suspension and see if they make a mount for it. Have you also checked your carrier bearing?
NCH
Proud Father of USAF Airman
2000 F350 DRW,CC,LB, 4X4, Western Hauler Pkg.
Ford AIS/ BTM, FTVB
My CCV MOD, Coolant filter
06 Grill, 05 lights,6.0 trans cooler
Cyro/Hawks, JVC Touchscreen HU, JL C5's, Infinity 800watt amp,
DP tunes, 60 tow/80 e/120 race, on a SCT2 tuner
P3 controller, Brite Box Turbo Lifesaver
KMC Wheels x 4
Friends Don't Let Friends Drive Trucks With Generic Tunes
NCHornet is offline
post #4 of 4 Old 04-21-2010, 10:32 AM
captivahach's Avatar
I would recommend new stock mounts if u wanna get rid of vibaration cause poly mounts are stiffer and I feel alot more Through the driveline
Just my opinion
2000 F250, 6" bds,20'' kmc hoss with 37'' Xtreme AT's. 05 front,08 rear,S&B intake,4" proflow full exhaust,swamps custom tunes, swamps S/175/146 injectors,powerslots, hawks, ss brake lines,05 warn hubs, Pricol egt boost trans gauges ,Custom built tranny, low stall billet convertor, 38r, srp1
captivahach is offline
